Hi,i am new here and I think i found a great community for my modding ideas...I a have the idea of building a framed htpc with metal angle 2'' X 2'' with surface in 1/4 plexiglass.I want something that will record video (pci tv tuner card) and maybe a mid-range 7600 gt graphic card I also think of amd in maybe am2 or older socket 939 with 1go of ram...
The ''special'' thing on this mod is that I will forge and weld all piece of steel together with a MIG welding machine.I have some question that need answer tought...
1)Where can I found a power and a reset button?
2)If I split tv cable with a cable splitter will i change tv channel at the same time if I change channels with the tv tuner remote?
3)Can I have all the hardware for less than 350$? (Forget about the steel and the plexi I have it free,I just want to know for the pieces...)
4)Is there a place where I can found mother tray
Thank!
