ok so here is what i came up for you
Swiftech MCP655™ 12 VDC Pump
Swiftech Radiator - MCR220 Quiet Power Series Dual 120 mm - Black
Swiftech Radiator - MCR120 Quiet Power Series 120mm Heat Exchanger with Fan - Black
Koolance RAM-30-V06 (RAM) Hydra-Pak Dual Ram Cooler
Swiftech APOGEE GTX Extreme Performance Universal Water-block
thats a mid-highend setup and accept for the ram cooler i plan to get for my first w/c setup. since you said you know what GTX block you want then i didn't add one.
