I'm starting a new mod, making most of the case from scratch. One part I decided not to fabricate was a motherboard tray and backpanel. But I found one which is missing three standoffs and all screws. Does anyone know what sizes these are?
Not sure what size thread they are, but you can buy a set of them:
http://www.mountainmods.com/brass-mo...ack-p-203.html
Radio shack also sells them in packs too.
I use to like radio shack, but they were taken over by circuit city and have gone right down the toilet.
I made a tray from scratch using #6-32 bolts & plastic 1/8" spacers..don't have pics up in my worklog yet, but it's getting there in the next few days. I cut groves in the plexi the same width as the nuts, and glued the nuts in the board so they can't spin. I prolly should have just threaded it, but i was worried about the threads holding up in the plastic.
If you look up atx specs (google it) you'll see the mobo hole dia. is about .15", right between #6 and #8 bolts.
"the bada and the bing"
I found that nobody has any sort of SATA, SATA II, or SATA 3GB/s cables, don't even bother... just make sure you order some or something. I wasted half a tank of gas to find this out today... what is it with stores and being "teh sucxorz"?
I'm with what 'is name, I'd probably order some. Speaking of which, I should get a variety just so I have some on hand for various things...
My Webcomic: www.fknsrscmx.com
My Myspace Music page: www.myspace.com/ryokenryagnaroth
My Last.fm page: http://www.last.fm/music/Ryoken+Ryagnaroth
My deviantART page: www.ryoken-ryagnaroth.deviantart.com
My Weblog: gremlinbutts.blogspot.com/
