For real this time. The case arrived in the mail today, and I promptly disassembled it. Plexi is on its way, so I have a few days to cut out all the fan grills, sand, and repaint it all.
Here's a couple pics of the case. I chose the new Coolermaster 690. I like the power supply at the bottom and all the mesh on the front, though it will be changed a lot.
The (short-lived) case in it's stock form.
The bottom vents for the PSU and an extra fan (the case came with a filter for this fan port)
Dual top 120mm vents. Not sure how because of tight clearances, but I want to try and fit a dual 120 rad in there.
The square opening has a mounting plate for yet another 120mm fan. This fan blows across the HDD bay, which is mounted sideways. I will probably cut out a lot of the HDD rack to allow better airflow.
The rear 120 vent, with pre-cut water cooling openings below it. These came with rubber grommets installed, but I already removed them.
I have many more pics of the case on My Site. I may reference them from time to time, but I dont want to burden the thread down with too many pics before I've cut even a single piece.
