hey all, I've been having problems with me wireless router ever since I started my new mod. Which are totally unrelated since the mod is still in the garage.
Anyways this is the equipment i'm using
DI-624 from d-link
DWL G-132 from D-link
Was wondering...if any of you may have some more expertise on hardware such as this. As most of you prolly should, i suck with wireless networks.
Ya, tech support can suck my b@lls I hate them and they are soooo stupidly redundant. I prolly spend about 5 hours with them and i get as far as what i've already done myself in about 45 min. And then they ask you to do it all again.
Ok so here's whats happening. The internet will have intermitent connectivity, periodically cutting out. Sometimes it says connected, sometimes it tells me i'm not, while i'm still surfing the net. Sometimes it just eff's off and i have no idea what it's doing.
I've just preformed a fresh format+re-install and just set up the router from scratch again. And the **** is in my opinion is a fantastic router....its just it's soo hard to get to work, they replaced my last one about 10 months ago, which is terrible since i've only bought it about 12 months ago.
Anyways any input on this would be super super appreciated.
Note: also see my other thread i'm about to create re: Asus M2A-VM mobo with AMD 5000+ X2 which i am having troubles with.
