Results 1 to 8 of 8
Thread: Vista 32 bit or 64 bit?
    Default Vista 32 bit or 64 bit?
    I am not to familiar with what this is, I never had installed an OS since I have bought all of my computers but what is the difference between this 2 versions? I am building a gaming computer and since I heard that the 64 bit versions uses all 4 gigs, I want to know if its worth to buy 4 gigs and use the 64 bit for gaming
    Remember Remember, The 5th Of November.
    Jul 2007
    Default Re: Vista 32 bit or 64 bit?
    For the average gamer i would say go with 2 gigs and 32 bit, it will save you alot of hassle with drivers. Like for me i went 64 bit and my wireless adapter doesnt have a driver, and after consulting google for an hour+ and posting here, i came to the conclusion that it would just be easier and more cost effective to run a 10 ft cable to my wireless router and plug it in. rather then buy an adapter that had a 64 bit driver
    Fresh Paint Kill_Switch's Avatar
    Oct 2007
    Nova Scotia
    For the 32 bit version, 2 Gigs is the G-Spot for this version. But the OS wont recgonize anymore than 3.5 Gigs, cause of the way its was written. For Now...
    With an upgrade to 64 Bit, Windows will see the extra 2 gigs when you go to 4 gigs.
    I friend of mine went to 64 bit and is a gamer, adn the 64 bit has given nothing but minor troubles.
    I suggest going with the 32 bit version, also, SP1 is comming for Vista soon.
    Quote Originally Posted by calumc
    I hide porn in my system23 folder
    . Spawn-Inc's Avatar
    Feb 2007
    ya i will be going with 32bit xp ( rather i already have it) and once i get my gaming rig complete i will get vista 32bit as well.
    Sound: Logtiech Z 5500
    Balhannah, South Australia
    I have 64bit and my games always crash, especially bf2142.
    Project: Elegant-Li *NEW*
    Project: Alpha FINISHED
    cool, thanks guys, Ill be sure to go 32bit as well. thanks for the help +rep for all
    No problem mate, we are here to help.
    Overclocked
    Aug 2006
    if all you useing is the mb and vidio card get 64 bit if you have aftermarket sound ect then get 32 bit.. havent notice much of a diffrence between 4 and 2 gigs but 64 bit like night and day faster...
