I've been thinking about building a pc inside a monitor and adding a working LCD screen in front of it to make it look like a normal CRT monitor.
I've got a few idea's about how to build the mod.
1e I'd take a old 17 inch or 20 inch monitor and take the hardware out, so i'd have an empty shell.
2e I'd build a metal structure inside the monitor to support the pc hardware and the LCD screen and making a sort of wall to sepparate the hardware from the LCD screen.
3e I'll try to build all the hardware on the metal structure and try to make it fit inside the CRT monitor's shell. I'll also try to fit the LCD monitor on the metal structure.
4e Creating the look of the monitor and getting everything to work just right.
These are the major lines of the things I have to do for this project. Of coarse I have to start with preparations to see if everything wil fit and al that.
My question for you is:
Do you got any hints or tips or advise about this project?
Sinds this wil be my first major project I could use all the help I can get.
The smaller project I did before this one was only a simple paintjob and cutting a side panel. Nothing as big as this.
Thx in advance for you help.
A starting case modder.
Silver.Draco
