I recently painted a keyboard and a mouse, but I need a clear coat over the paint. What would be the best thing to use?
It is the quality rather than the quantity that matters.
Author: Lucius Annaeus Seneca
Be true to your work, your word, and your friend.
Author: Henry David Thoreau
try to use the same brand of paint you did your coats with. bad things happen when you mix and match brands.
Intel Pent D 2.66Ghz| 2Gigs| 18x DVD-RW| 200, 40 GB| 550W ATX| Zalman 9500
ok thx for the quick reply, ill try to find some of the same brand at my house. I will try to get some pics on here when I get finished.
