Results 1 to 3 of 3
Thread: 19V Adapter for a 12V monitor.
    Default 19V Adapter for a 12V monitor.
    Hey guys, I'm not too sure if this question has been asked before, since it seems like a question that might be frequently asked, but search didn't help me at all. So, I was wondering, is it safe to run a monitor that requires a 12V input from an adapter with an AC adapter that outputs 19V?
    I really don't want to spend money to buy a new adapter and just wanted to make sure, in case something blows up.
    Thanks.
    ^ Soon to be one. Computer-Geek's Avatar
    Nov 2006
    New York
    Default Re: 19V Adapter for a 12V monitor.
    I think it would be better to buy the Correct AC adapter
    - Computer-Geek
    baaah. billygoat333's Avatar
    Aug 2007
    Idaho
    yeah, def. want to buy a new adapter. especially if the amp output of the 19v is a lot higher than the 12v. if the amps are about the same, then the 19v would be somewhat ok to use as a temporary thing, but if you have an expensive monitor, i wouldnt risk frying it.
    Quote Originally Posted by Omega
    ber is id elicous
