have windows xp 64bit currently running i wana do multi boot so i can xp64 or 32bit how do i do this...i have xp32bit cd but will not let me install what should i do people????????????
Have you got a valid license for both copies of XP?
yes boss i have valid license for both...i downloaded from my university site. they give this software out for free to students with license.
Install the oldest version first. Is this where you are getting the issue? Please expand your explanation of the issue.
i have already windows xp64 on the system running...i would like to add windows 32bit onto the system now so i can have a multi boot screen letting me choose which system to run...
is there not another way? as i have loads of software and data on the current system already.
2 different HDD or only one?
Would you consider putting the 32bit in a VM environment?
i have got 2 x 500gb hard drives.. one hard drive has xp64 and the other just random movies...
i dont want to get rid of xp64 only as a last resort.
I'm trying to dig through the cobwebs here. Obviously, you have a free partition, or are you going to put xp 32 on the second drive? Either way, you'll have to edit boot.ini, and here's an article from M$ on how to do exactly that..
http://support.microsoft.com/kb/289022
Of course, I recommend backing everything up first.
