Re: multi boot help pleaseeeeeee
I still say its better to just redo you computer. You will be happier in the end.
tryin to get rid of xp64 from my computer no luck how do i uninstall it?
Reformat. You aren't going to be able to do it without losing your data*. Backup you stuff and reformat.
*Unless you have everything on a separate partition except for Windows, then you only need to delete the Windows partition during the new Windows install.
i've backed up all the data now how do i format the drive?
Insert the Windows XP CD and follow the prompts.
okay because i was going nuts loll...i took the hard drive out slinged it into another pc and formatted now that i put it back into the orignal pc and boot it...it comes with a NTLDR is missing error...
i know some genius has got a solution to this....
Errr ya.... that was not smart. NEVER put a HD into another PC and format. Always do it in the same machine to make sure all of the drivers match up in the end. Make a 98 boot disk and FDISK the HD you want to install your OS' to. Make 2 partitions and put 32-bit on the first, and 64-bit on the second. That should be fine. Let me know if you need more help.
Banned
look at my reply in the other thread you started.
i have a 500gb hardrive and its only showing like 130gb hardrive how come!!!!?????
