Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Thread: multi boot help pleaseeeeeee
  1. #21
    t3h f3cKiN 33Ji7 calumc's Avatar
    May 2007
    Co. Sligo, Ireland
    Default Re: multi boot help pleaseeeeeee
    did you by any chance make a 130gb partition?
    Quote Originally Posted by Crazy Buddhist View Post
    I'm starting to worry that I may become genuinely funny at some point. Then there will be no hope.
  2. #22
    nope in the boot it detects it as a 500gb harddrive however when wen to format it via xp it only shows up 130gb...
  3. #23
    Nov 2006
    Montréal
  4. #24
    okay another problem is that every about half hour my screen goes blank and it comes back on and it changes the display settings..the ati graphics control settings are perfectly fine just the screen settings changes why is this???
  5. #25
    Nov 2006
    Montréal
    latest drivers?
  6. #26
    yes boss i have the latest drivers from ati website.
  7. #27
    Nov 2006
    Montréal
    Almost sure it's a problem with the drivers, try to uninstall them; using Driver cleaner and reinstall them.
  8. #28
    got a problem with cmos in the boot part.. it always something that cmos settings changed and its running in safe mode and press f1 to continue..an solutions to this?????
  9. #29
    Jun 2006
    In the Redwoods
    dead battery?
  10. #30
    it cant be the battery....well that problem i shall try to do later
    got ultimate vista yeh when i restart pc n boot from cd it wont boot the vista cd
    also when i login into my windows n double click cd n it give me an error sayin you cant install it like this use the install media..
