Results 1 to 6 of 6
Thread: Might go SLI...Power?
    Default Might go SLI...Power?
    Thinking of going with a second video card in SLI. Specs of my PC below....3 120mm fans also running. Do I need to beef up the power if I add another card?
    ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD
    Western Digital Caviar RE WD2500YS 250GB 7200 RPM SATA 3.0Gb/s Hard
    EVGA 640-P2-N821-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
    AMD Athlon 64 X2 6000+ Windsor 3.0GHz Socket AM2 125W Dual-Core Processor
    COOLMAX CUG-700B ATX 12V( V.2.2) 700W Power SupplyLITE-ON Combo Drive Black SATA Model SHC-52S7K-05
    2 CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4DHX - Retail
    Antec Performance One P180 Silver cold rolled steel ATX Mid Tower Computer Case
    Jan 2007
    Montana
    Default Re: Might go SLI...Power?
    This calculator should tell you what you need.
    My Flickr Stream
    LOLWUT?! Scotty's Avatar
    Jun 2006
    P'boro, England
    700W should be easily enough, TRiSLi with ULTRAS pulls just over 800W
    But i havent heard of that PSU manufacturer before so it might be a better idea to upgrade the PSU to a decent one, Tagan, Seasonic, Antec, Corsair, you wany 650W minimum really just to be safe.
    Jun 2007
    Your cookie jar
    That power supply should be fine. 3 12V rails. One at 16, one at 17, and one at 25.
    Reviews are all super high as well. It should work. That being said, if it doesn't keep up then upgrade, but I don't see an issue with it.
    Jan 2006
    Normal
    [DIGG]dig it[/DIGG]
    read my comic already! (sig) xRyokenx's Avatar
    Dec 2006
    Bloomingburg, NY
    Quote Originally Posted by DrumThumper View Post
    I tried it out and it seems a little outdated... it only went up to the 6800 series and Pentium 4's as far as I can tell.
