i know that many of you are using dual monitors, so this is the program i use
ultramon 2.7.1
this wonderfull program makes another "task bar" in the bottom of your other monitor and you can choose different wallpapers n´ stuff... the posibilities are endless
and with my wallpaper setup
this is a nice program and easy to get the trial version is free and then you can buy it or whatever you want...
get it here: http://www.realtimesoft.com/ultramon/
hope its usefull
-p0Pe
