this is a simple little paint and window mod. its not quite finished but i figured i would post my work so far.
the initial concept
some primer work on other case parts
the initial concept
- Curse not thine evil fate
yay more photos.. ya i know primer isnt very exciting... so now for something completely diffrent!!
yep... red paint.
ok so the front panel and inside are done painting. time to assemble them
there must be some more things i can paint.
ok so here is the front panel installed onto the frame
if it wernt for the wires you wouldent even know the power supply is there. seems to blend in nicely
now lets install some other devices
things seem to be blending in quite nicely
ok time to move away from painting for a while and work on some of the fun stuff
lets start cutting the window
measuring out my plex
i have my marks set and the plex is seccured to the back of the panel. were ready for drilling now.
see... i said its seccured.
because i drilled them both at the same time i know the holes will match up perfectly
dont forget to mark wich end is up
dont worry i havent abandon this project. just some things to sort out with the panel that made it look like junk after the paint job. resanding it and repainting it so it looks good enough to be on this forum. :-)
yay i finished painting the side panel. i have installed the plexi but find that it needs a wash. must have had some crap on my hands when i put it on. there is only one more part to be installed. will post photo's of this when i get home.
its interesting working on 2 mods at the same time. seems that when you are waiting for parts for one you can just work on the other. i think i would not mind working on 2 at the same time again.
after some paint the side panel looks like this
once in installed the plexiglass on the panel and put it togeather with the frame
for this one i really messed with the exposure time on the camera. its not really quite this orange but i thought it was an interesting pic so here ya go
there are feet on it just not illuminated ones.
Link To Original Worklog
