Results 1 to 4 of 4
Thread: ATX Server case (Possible build?)
    May 2007
    Florida
    Default ATX Server case (Possible build?)
    I found this cool-looking server case on Craigslist, posted at $75. I noticed it was at $100 earlier, maybe he'll take $50-$60 for it.
    It has 14- 5.25" bays, and 1-3.5". Two 80mm fans on the back and a slot for an ATX motherboard. I think there may be another slot for an ATX board, but I can't tell from the pics. It doesn't seem to have a brand name either.
    I was thinking a Huge side-window made out of Lexan/Plexi. And some Cathodes in the front on the sides. Should I buy it?
    E2180 (2.0ghz) | 2GB DDR2 800 Tracers | 8600GT 256mb | XFX 610i nForce mobo | Lanbox Lite
    Intel Atom 230 - 1.6ghz | 2GB DDR2-667 | 945GCLF Mini-ITX | Apex MI-100 case
    Oct 2007
    Kinshasa, DRC
    Default Re: ATX Server case (Possible build?)
    For that cheap... why not.
    How much faster can you render the bsod? Ap1thy's Avatar
    Jun 2007
    New York
    you could fit a 480mm rad in the front of that thing and have space left over...
    Overclocked si-skyline's Avatar
    Apr 2007
    sheffield, eng
    i say yes too.. iv got something similler to that and you can convert all those nice 14 slots into hard drive conpatible ones and before you know it lots of hard drive space xD
    Basic Math:
    1 + 1 = 2
    1 * 1 = 1
