I accidently forgot to use something as a layering underneath one of the side panels when I was sanding and made a dent while holding it in place using a gripper. Does anyone know how to undo the dents?
If you cant pound it out using a rubber mallet, then you might have to use bondo to fill it in, then sand it smooth.
depending on the size, epoxy often makes a good filler as well using the method Luke described. Sometimes I've heard that bondo can pop loose when sanding if your dent is too round and smooth.
From my experience with bondo its great. Just make sure you apply it to bare metal and that all sanding dust is cleaned off so you have a good clean contact.
