Right I havent been active on here in ages but hopefully some of you guys still remember me
Anyways onto my problem...
Im running a pretty standard piece of crap: 3ghz celeron, 1gb ram, some crappy foxconn mobo all powered with a cheap 250w psu.
Im currently dualbooting with xp and ubuntu. So the other day i was working away in ubuntu when a thunderstorm starts, the power goes out for a second and comes back presumably with a little bit of a surge.
Computer boots up and when the xserver starts i get a 'signal over range' message on my monitor. Ive seen this before and it usually just needs a re-setup of the xserver to get a correct config file. doesnt work. i try booting off a live linux disc, same thing. I try a different graphics card, same thing.
But this is the truely weird bit; windows works fine.....
So any1 got any ideas??
