More wok, nice job.
More wok, nice job.
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
lol well there will be more of an update today i have alot more time!
what do you call that concoction you created?
Every passing hour brings the Solar System forty-three thousand miles closer to Globular Cluster M13 in Hercules — and still there are some misfits who insist that there is no such thing as progress.
Kurt Vonnegut - Sirens of Titan
hmmmm i havent thought of a name for it ill come up with something and let put it up here
update in a few mins!
Ok guys next update!
I HAVE MY FIRST SPONSOR FOR THIS PROJECT!!!
check my first post...
and on with the work.
I started working again on the angled pieces for the hdd module and got them all polished up
I then came up with a way of getting all the holes drilled in the right place
and done
First hole on the hdd module drilled
Tapping both the acrylic and the module for an m4 socket head bolt
first angle done
jumping forward all 4 done
then i just thought i would randomly stack up the pump/res, hdd and dvd modules as they were at the time!
I then got the angle pieces for the dvd drive module cut out and polished
then drilled
and mounted!
then i thought i would just take the two modules that i had done the angles for inside and weigh them
these two weighed nearly 3 lb together and thats without the ends and the hardware so this is going to be one heavy case!
then i took the hdd cage out of my current case for modification
I then took my bench grinder to these tabs etc that arent needed
and to some more bits on the bottom that arent needed and just get in the way
And this is what i was left with.
then i took my dvd drive and marked out the front of the module for cutting
and done
and thats it for today!
Hope you enjoyed it.
I have the same amount of time tomorrow to mod so be sure to check in and see what i have accomplished!
Josh
You should stealth that dvd drive front.. that would look sweet.
Hell yeah, congratz on the sponsor mate. Crucial always seem to help out a modder in need, good to see their support once more. The mod is coming along fantastically, can't wait to see it all together.
