Results 1 to 6 of 6
Thread: Picking out the right memory...
    ATX Mental Case Vexxx_2007's Avatar
    May 2008
    Default Picking out the right memory...
    As some might know by looking at my "My System" drop down thingy, i use old-school DDR memory. i only have 1gb of it though and it's about time i dropped some pocket change and got 2gb. My current memory is mix-matched stuff and really slow. My motherboard supports a max. of 2Gb.
    But i have a simple question that i should probably know by now, but does the memory speed matter when upgrading? my two stick of memory are at 200 and 133 mhz and the ones i'm looking at buying are 400 mhz. will these work in my pc? or will only a genie know this answer?
    Here are some of the products i've been looking at:
    2x Ultra 1024MB PC3200 DDR
    2x Crucial 1024MB PC3200 DDR
    2x Corsair 1024MB PC3200 DDR
    Any suggestions? these are all really cheap so whichever, in your guys' opinions, is the fastest, will be the winner in my pc
    EDIT: i'm leaning towards the crucial, cause i saw an ad of their's in a GFW magazine one time... they looked pretty legit..
    “An intelligent hell would be better than a retarded paradise”
    -Victor Hugo
    read my comic already! (sig) xRyokenx's Avatar
    Dec 2006
    Bloomingburg, NY
    Default Re: Picking out the right memory...
    I'd go with the Crucial because it's cheaper and the latency is pretty good.
    Fox Furry crenn's Avatar
    In the shadows behind you
    All of that is budget RAM, the DDR-400 will work fine in your motherboard. Although my RAM is rated at DDR2-1066 and my motherboard doesn't technically support that speed, it still works fine.
    May 2008
    Quote Originally Posted by crenn View Post
    Yes i know it's budget RAM, but this pc is kinda old... and i think it only supports DDR memory anyway.
    The model is K7MNF-64 and as far as i've found out i can't stick in DDR2 memory
    -Victor Hugo
    Feb 2008
    Detroit, Michigan
    If your motherboard doesn't support the speed, or you have slower memmory in there, it just underclocks the new stuff that you put in. You could "overclock" it to run at it's rated speed, if your motherboard supports that.
    Ram works as fallows.
    If it fits in the memory bank, it'll work. Might not work at the rated speed but it will work.
