Results 1 to 6 of 6
Thread: Cheap cable sleeves
    Resident Alcoholic
    Nov 2005
    Chichester, England, uk (NOT Scotland)
    Default Cheap cable sleeves
    Hey!
    Im not sure if im being innovative with this, or whether it's been done before....
    but I thought that I should share what little i can with you all in return for the advice this site has given me!
    I realised that all my psu wires were restricting the airflow in my case, I decided to come up with a way of sleeving them.
    Sure, it's been done many a time before, but I am poor, and im sure there are others out there who cant realy afford specific psu cable sleeves!
    I spent ages trying to think of a way of doing this, then I gave up and went to do some coursework for my a-levels...
    which is when I stumbled upon these things:
    Comb binding rings:
    They are used as cheap binding for documents, and work perfectly for holding your wires together!
    I picked up a 50 pack of them for 1 quid (2 dollars) at my local stationary store.
    I also used a similar ring binder to hold together the main clump of wires that go to the motherboard, and its all now much neater and works nicely.
    Happy modding
    H
    Rankenphile
    Guest
    Default Re: Cheap cable sleeves
    Very clever. I worked in a print shop for years, and used these all the time.
    Allow me to do you one better. :p You can, in the same spot, usually find plastic spiral bindings. They come in a very wide variety of colors and sizes. I found a website that sells them here by doing a quick Google search, I'm sure you could find more easily by doing some homework.
    I had never thought of using them for this, though. Neat idea!
    Chicago, IL
    only problem I see is they are pretty stiff and I'm not sure how well they would look if bent, but good idea.
    if you want other cheap ideas just go walk around your local hardware store, I can't tell you how many times I'll be walking through home depot and go "Hey, that would look sweet in a case!"
    Resident Alcoholic
    Nov 2005
    Quote Originally Posted by Rankenphile
    These do look even better!
    The comb bindings can be a little stiff, but they do bend into shape an keep their shape once theyre round the wires - I'll try and get some pics of my case tonight
    Case Wizard
    Split loom is kinda nasty . To me it looks like those crazy straws that you use to drink slushies. Except split along the middle.
    Also, has anyone heard of snakeskin? It's a mesh weave that expands to fit over whatever you need and contracts again. Sort of off topic.. I can show a picture if you don't get what I mean.
  1. PCI Express Extension Cable?
    By adsmith82 in forum The Rookie's Nook
    Last Post: 06-17-2010, 10:39 AM
  2. Little Blue
    By DRece in forum Works in progress
    Last Post: 01-07-2007, 04:13 AM
  3. a cheap compfor my friend
    By Durrthock in forum The Chatterbox
    Last Post: 12-24-2005, 03:59 AM
  4. I need a cheap dremel
    By Sisp in forum Hot Hardware Deals
    Last Post: 12-15-2005, 12:49 PM
  5. UV Reactice cable insulation
    By {eVo}Ceribrus in forum The Rookie's Nook
    Last Post: 05-29-2005, 09:13 AM
