Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: [Project] Midnight Sparkle
    Default [Project] Midnight Sparkle
    Hey there guys,
    Im back again with another mod, This is Midnight sparkle that i am doing for my girlfriends new computer.
    as usual its a scratch build.
    Here is the initial design which changes a bit as you will see very soon(im not doing another version you can see in the pics)
    I started off this long day of modding by clearing stuff a bit so that i have room to mod again
    And on with the modding
    (sorry for the blurry pic...)
    I started by cutting apart my old case to give me a mobo tray and a template for the psu.
    mobo tray cut down
    and even more
    psu template
    I then cut the 2 bits of alu that i need for the main body of the mod
    and bent the longer bit to shape
    here it is with the side panel sitting on it
    and mounted
    front and back marked out
    and cut
    back marked for cutting
    cut
    mobo tray mounted
    Window cut
    and filed
    and mounted back on the case
    Acrylic for the window marked ready for cutting
    and placed on the outside of the case
    i then marked the alu angle ready for cutting into the joints
    and cut
    I then started work on the case feet
    and glued
    i didnt get to file, sand and polish them today but i will get that done tomorrow and then i need to order more bolts and get some more rivets tomorrow so that i can get this done. this will be one very quick mod butttt i did work on this from about 10:00-18:30 with a 1 hour break in the middle hence why i got a lot done
    and just to give you guys some perspective of size this is smaller than the mobo section on modularis
    Check in tomorrow
    Josh
    A big old Tease Apparently DonT-FeaR's Avatar
    Sep 2006
    Australia, south australia, Gawler
    Default Re: [Project] Midnight Sparkle
    shiz man.... heaps done.... i did all doy work and didnt get half that amount done.... good work
    you tease!
    ATX Mental Case Yeticorn's Avatar
    Oct 2008
    PA, USA
    Nice, gonna be following this one too
    +rep
    /sub
    Lol thanks guys
    and Dont-fear yer i wanted to get this done as quick as poss so i just got on with it and thats what i was left with lol
    Josh
    Jun 2008
    MA
    looks neat so far, I like it
    Thanks mate
    josh
    Anyways today i didnt get much time as i was with my girlfriend but i did get the feet polished
    Josh
    Does all his own stunts mittelmeier's Avatar
    Aug 2008
    Looking good. Since it's her case you should've had her out there helping you.
    j/k
    Lol she was out there but she was reading a magazine...
    Josh
    Sep 2006
    lol
    get her in on it to josh.... gosh..... she could like pass you tools??? at least
    you tease!
