Results 1 to 5 of 5
Thread: Aquamark 3
    50 Custom PC's in 10 Years! TheGreatSatan's Avatar
    Southern IL
    Default Aquamark 3
    I can't get Aquamark to run all the way through in Vista. I use it in XP with no problems. Usually the test runs the whole course, but right when I expect to get a score, I get an error instead. I can't find much for Aquamark when I do a search. Is Aquamark dead?
    NEW GENESIS
    Modified Azza Genesis with an Intel i7 2600K, Gigabyte Z68X-UD3H, 32GB (8GB x 4) Corsair XMS3, 960GB Crucial M500, 240GB Sandisk Extreme, 1275 Watt Thermaltake 80 Platinum Modular PSU, Gigabyte GTX 780 OC 3GB, and a Corsair H60
    read my comic already! (sig) xRyokenx's Avatar
    Dec 2006
    Bloomingburg, NY
    Default Re: Aquamark 3
    I could never get it to work in Vista. My computer has the same issue as yours... I'm assuming that Aquamark is just not compatible. Hehe, I still have not run any benchmarks on this thing.
    Jun 2006
    The Dairy State...
    Nope, it's not compatible. However, there is a patch that will allow it to work (64-bit). I got to setup two PCs at work to showcase a Gamer's Setup and Graphics card/PSU install on identical HPs and all we could get to work was Aquamark with the patch. Patch.
    And yes, Aquamark is dead. Aquamark 3 is from 2004, and I haven't heard of any updates to it.
    RIP Bucko
    Southern IL
    It was so pretty by 2004 standards, imagine a 2008 version.
    NEW GENESIS
    I stole p0Pe's cake FrooP's Avatar
    May 2007
    in your fridge
    hmmm dx 10 underwater lighting effects :drool:
