Page 1 of 7 123456 ... LastLast
Results 1 to 10 of 62
Thread: Dragzon Case
    Sep 2006
    Malaysia
    Default Dragzon Case
    Hi,i just joined TBCS today would like to share my case project.
    started in 2005
    :blush: Juz planned to start a case project,as a hobby
    Welcome To My Worklog Project!!
    cut into half
    Finally started this project
    Took off everything from my old i cute case and transfered to a temporary [enlight]case
    which im gonna use for the project also[i cute case]
    Drilling Out The Rivets
    All the sections are dismantled.
    Just bought CM Centurion 5 from Gadget Zone :drool:
    more updates after my final exam around november
    :unsure:
    The theme of this case will be in flames[still thinking] and custom fan grills etc more plans coming
    PC:AMD Athlon 64 X2 5200+ with TT Ruby Orb ,Abit AN52S ,1GB x2 Kingston DDR2 667,
    Gigabyte 8500GT Ultra Edition 256mb DDR3 [Oced 700/800],Maxtor 40GB,Maxtor 120GB,Creative Audigy Value,Creative Inspire 4.1,Modded Casing
    Sep 2006
    Malaysia
    Default Re: Project:Dragzon Case
    went to hardware shop to get some wires,led,switch
    decided to start the psu mod :thumbs:
    opened the psu and cut off the stock fans
    fixed blue led fan
    fixed cm uv fan
    screwing cm uv fan on the Sunbeam Psu Uv reactive Case
    Double sided tape the sunbeam psu uv reactive case.
    Finally Is Done!
    note: the crack on the sunbeam psu case is not by me,someone else............... :w
    PSU Under UV light
    [img]http://img288.imageshack.us/img288/7750/96ov.jpg[/img
    Sep 2006
    Malaysia
    Time to cut a window
    Halfway cutting through
    Separating the cd rom bay and the fdd&hdd bay[not using]
    Finally Done,and just riveting the bar for the cd rom bay
    still need to file and sand paper tommorow continue,
    :thumbs:
    Another Update for today :drool:
    cut it into half
    Taking off the part that i dont need
    Riveting it
    Finally Done,needs a respray
    the case gonna plan for future use water cooling
    Sep 2006
    Malaysia
    Took a pic of the case got nth to do :o
    due to my rotary tool[unknown brand] died.
    anyway since i cant do any cutting work :cry: ,so i decide to do this strip off some stuffs ,since 1 week break do some mods :flex:
    gonna spray int[black]and see what i can do
    Done A Little mod for today
    fixed the rubber legs from cm5 so there is a space for the ccfl,took off the ccfl from the CM ccfl tube and transfer it to a Rubber Tube as shown in the pic
    Testing wether the ccfl is smash i guess,juz fit nicely :thumbs:
    thats all for today, need to get 3/8 barbs,5 Black Spray Cans,silicon,epoxy glue :o $$$ :sweat:
    Sep 2006
    Malaysia
    Did a little mod Drilled holes for rivets,testing the rivets wether they fit
    :thumbs: :flex:
    juz cut off the honeycombs so better air flow
    sry my cutting is not so perfect due using a drill :blush:
    Finally got Rtx1 and Work Bench, and some stuffs
    Sep 2006
    Malaysia
    cut a hole so psu wires can go through
    Received Some stuffs
    Sleeving The Psu wires,Not Finished Sleeving yet
    took off the top case part need to cut to make it as long as the centurion 5,noticed is longer abit the top case
    Taking Off the top case
    Cutting out the piece need to be cut
    Very satisfied with my work today
    really need a respray, still gotta find a way to rivet the Top Casing.
    Sep 2006
    Malaysia
    fixed cm 120mm fan behind
    Planning to make the front panel
    Took out the c5 badge from the centurion 5 front panel:p
    Measuring the front panel
    Continued
    Doin some sleeving
    Having Hard Time to cut 3mm arcylic :blink: ,halfway done
    Sep 2006
    Malaysia
    Cutted those bezels out
    Done cutting the front panel bezel's file + wet sanding edges
    Use epoxy glue to glue those sides
    top panel glued, i know u can see fingerprints tomorow i will cleaned it off
    Tested Fit
    Update,fixin the electronic key hole
    sprayed the inner part of the front panel
    heres the finish product of the Front panel :drool:
    can u see the reflections of the tiles? :thumbs: :drool:
    Sep 2006
    Malaysia
    anyway thanks,heres a close up of the front panel
    sry for poor quality pics
    fixed the top part arcylic,anyway gonna have a top blowhole for it and some designs later on,
    close up wit better lighting
    as u can see i sprayed the inner part black colour
    more updates tomorow
    Nothing just teaser's pics
    just received
    Vantec spec uv Led blue-green
    2 fan grills
    2mm 1ft x1ft arcylic
    sidepanel.
    :drool:
    Sep 2006
    Malaysia
    back under night,sry for blur pics
    Still not satisfied with my top back panel.gonna redo again
    Update For Today, note Tons Of pics today!
    Bought some stuffs today,paint,the saw is for my project for KH [school project]
    ok have a look at this pic,see the red circle i drawed,theres a gap,so im not satisfied.and i threw away the back panel arcylic!
    heres what i did today redo the back panel
    [img]http://img501.imageshack.us/img501/9510/img0672medium6sc.jpg[/img
  2. Making a case from Scatch
    By rogersthegod in forum The Chatterbox
    Last Post: 01-12-2007, 05:08 AM
  3. HTPC Silverstone case mod (an idea)
    By runninkyle17 in forum Idea Zone
    Last Post: 01-08-2007, 07:38 PM
  4. Modding a case - need newbie tips ^^;
  5. New guy and his fallout case ideas
    By DaveW in forum The Rookie's Nook
    Last Post: 01-18-2006, 02:54 AM
