I finally got my new UPS in the mail.
You know I'm gonna Mod this right?? It will be getting repainted and I'm gonna add a window or two or three.
WH1T3 0U7
Modified Thermaltake View 37
I've got a theme!
WH1T3 0U7
I've nearly completed my degree in electrical engineering so I know what I'm getting into.
WH1T3 0U7
I think it would be difficult if not nearly impossible to actually make it look like a Winnebago, so...
Should I just buy a winnebago and chop it up, then reassemble it around the UPS?
WH1T3 0U7
PISS OFF, you spammer. Every damn thread....
WH1T3 0U7
I got the Winnebago in the mail. Till I need it, my kids will happily play with it.
WH1T3 0U7
The winnebago is 22 inches long and the UPS is 17 inches long.
WH1T3 0U7
I finally took some size comparison pics.
WH1T3 0U7
That's because it's dangerous and I'm crazy for attempting it.
WH1T3 0U7
Alrighty let's get started. I gutted the Winnebago.
I opened the top.
And dropped in the UPS. It's a perfect fit as far as length and width, but height.....
When I measured it before I assumed that the height of the winnebago was the same on the inside as the outside. But I never really considered the bottom.
The inside is just 17cm
The UPS is 22cm
And the outside of the winnebago is 22cm....
I could fabricate some kind of shell with the wings attached that could go on top to cover the top of the winnebago. Or pull out the bottom and set it lower. What to do?
I rented the movie too.
WH1T3 0U7
