Hello all, i am very new to modding but have a big interest in it.
For my new pc i will be installing everything my self (of coarse)
Now, the problems i am having is with the led lights, multiple fans and neon sticks.
What i don't know is how you connect multiple fans, multiple led lights and neon to the power supply.
Here is what i am going to be installing...
~~::Laser Lights::~~
http://www.gamedude.com.au/prod_show...aserbeam_green
~~::Neon::~~
http://www.gamedude.com.au/prod_show...SUliq_rgb_spir
http://www.gamedude.com.au/prod_show...SUliq_red_spir
~~::Case Feet::~~
http://www.gamedude.com.au/prod_show...SUcasefeet_red
~~::Fans x 5::~~
http://gamedude.com.au/prod_show.php?art_no=coBR8blue
All installing in this case:
http://www.gamedude.com.au/prod_show...iper_black_red
(this is not the prob. the prob is the installation itself.)
Here is the power supply i will be using:
http://gamedude.com.au/prod_show.php...=psXGvortec600
Now, how would i go about installing those 5 fans and all those lights and neon to that power supply (keeping in mine the motherboard, hdd, dvd/r and dvd/rw are also sharing the power cables from the power supply.
Do i need to buy something else to connect them all to the power supply outlet plugs? Or is there a bit of hard wiring required?
Also: i want to be able to turn the LED (foot lights, laser lights) and neon off and on with a switch (to save power when not using them)
If you could help me with these with either a tutorial or verbal it would be greatly appreciated.
Cheers,
Viper-Inc
