Does anyone think its possible to have a PC case that is completely sphere?
This is something that I thought of when I was half asleep.
On the outside it would look like some alien Sphere. Completely chrome and finished with some tech indentations on the metal. The cd drives are hidden along with the fan bays. (Moreless for Show and transporting) Made of a plastic and an outer pannel of sheet metal like the rest of the case. The cd drive bay covers will fold out when the drives are ejected. The inside will probably the the tricky part. building mounting brackets for a square or rectangle motherboard inside of a round shell. The other bays for your other cards. pci agp so on. those can have removeable covers like the fan bay coverings.
Opening the case. I was thinking of 4 release buttons that are flush with the case metal on the outside and 2 are located on each opposite side of the case. Pushing all the buttons in will release the 2 hemispheres of the case and if you lift up it will open and show you all your working components. I was thinking of mounting the motherboard laying flat on a mounting sheet for it that attaches to the lower hemisphere of the case so it lays horizontally. Depending on how small your motherboard shall be is how much lower you can put your motherboard into it.
Myself I didnt get to think about how or where to put the hardrives or the cd drives. I do think though if someone did make this case it would look very sweet. Maybe with a vew clear water cooling tubes coming from it and have some glowing effects coming from them. it would only add to the alien look of the case.
I know some people will not like this or just think it cannot be done.
I would do it myself but I dont have the equipment, time or money to do it.
I really didnt have much time to draw out a example. But if any of you want to attempt to make this please do so cause i would love to see how it will turn out with your changes or what not.
Thanks for reading and please tell me of some flaws with the design if you think there are any.
