I thought I should post some pictures of my two computers for you guys to check out:
My gaming one (the one I'm on most often):
EDIT: My pictures weren't working so I fixed them, but now they are thumbnail-less
A nice angle
Detail of the front temp display. I swapped out the blue LEDs for those curved things on the sides with white ones to match my theme. I gotta open up the bezel again to see if I can swap out the blue backlight LEDs for the display...
The front ports and jacks. I added that red switch on the left to turn the white cathodes on and off. I also need to do some dusting :/
Check out that cable management! It took me about 2 hours 'cause I removed part of metal drive bay thinger. I did that 'cause it opened up a lot of strategic cable routes. I also added that fan to the window. I put it right there in the middle like that so that it would help bring my GPU temps down a bit (I was havin' some problems with it overheating).
My computer upstairs:
A nice picture of my 3 LCDs (I have a fourth one, but I lost the power supply for it... :/ )
In the dark...
With the side of the case off
A newer picture, with all of the video cards in and that annoying blinking fan unplugged. I should probably just take it off the mobo and remove the LEDs so I can remove the annoying factor without losing the cooling.
With flash this time, so you can see the cable management! I need to sleeve those wires though :/
Phew! Now that's over with, tell me what you guys think!
