You want some info? I'll be glad to help you. Some stuff to learn and don't rush, glad you asked. There is good stuff and bad stuff to buy, basic rules (physics) we have to follow, and how to install it all.
Best bet is to get a drink and read all the stickies here and in the links I provided, look at all the rigs especially your case or planned case. Spend a few days. Here is a quick primer I keep to cut n paste and places to look.
Okay! Great to have you here. You need to research and learn about WC first. We'd rather you spend 2-3 days learning than spending 3 weeks with basic questions that we shouldn't need to worry about.
For your benefit please spend a few days reading a LOT. Here and at the busiest places for WC masters. Guys who have done it for YEARS at OC forums and xtreme forums. It took me a while (I was OCing on air, aftermarket stuff, bios settings, best chipsets etc etc) to learn the language and the tricks to a easy install.
Don't expect miracles, or SUPER DOOPER over clocks. What you will get is a quiet system that can handle OC to the max of your hardware IF you buy quality and buy smart. And minor maintenance too, a bonus for the water cooler.
Also while there please read on case mods etc. The radiators are not for small cases, the pumps and hose routing, wire management and other things are important to understand. Google your planned case and the word water-cooled in one line. You might get lucky.
IF you just cool your CPU and your NB if you want, you can get by with a 120.2 sized radiator (RAD). And MAYBE fit in inside depending on your mod skillz. You want to cool your GPU too, you'll need a 120.3 sized rad, and it won't fit inside. The rear external rad really works great. No matter what your adding 15lbs to your PC, maybe 20lbs.
Once you got an idea of what is good/bad then start getting your system for WC put together and we'll be glad to help.
http://www.xtremesystems.org/forums/index.php? Not a noob site, but great stickies
http://www.ocforums.com/ My fav, good peeps, know their stuff, less hardcore
http://www.skinneelabs.com/MartinsLiquidLab/
http://www.over-clock.com/ivb/index.php?showtopic=20277 A GREAT Europe site
http://www.overclock.net/water-cooling/
http://translate.google.com/translat...hl=en&ie=UTF-8 Info on rad testing
http://skinneelabs.com/
http://www.dangerden.com/index.php?o...tpage&Itemid=1
http://www.petrastechshop.com/
http://www.sidewindercomputers.com/
Hey folks, where was that link from another forum that had so much info it was amazing! Was posted here mebbe 2 months ago, I lost the link, be a great one for him to read
