Just having another idea here that I don't have the funds to build.
Was looking into building an HTPC for my bro and started thinking of what I wanted. lol..
I was looking at the ones with the touch screens and though how small the cases were with that in there and then saw the price. They are crazy!
I was looking at an 8" LCD Touchscreen with USB connection and VGA input. Thought that would be cool to have in the case over those 6.5" ones. Then I saw the price again and it was $370 just for the monitor. OK, at least you get a bigger screen for it. But what about a Car Deck instead? 6-7" screen, multiple inputs.. under 300 for some and would take up about the same or less room in the pc. Or both? lol
I was looking at tower cases to mod. If using the 8" screen, the case is going to have to be at least 8" wide and that is a snug fit (width is 7.92"), and if the tower is set on its side, it has to be at least 8.2" wide (height is 8.16"). The depth is only (with the casing 5.5") so that wouldn't be a problem.
Then I was thinking of building the case out of aluminum or sheet metal. I'm thinking sheet metal because it is probably easier to get a hold of. But I don't know what would be a good thickness to support it, and how do you make perfect 90 degree bends without the proper tools?
Here's a picture of what I was thinking of the front.
or the 120 can be side mounted and have another one on the other side. All the fans would run at low speeds to make the least amount of noise. I would like to be able to upgrade to better hardware in the future and the way the graphics cards are, depth would have to be considered. At this time I would probably put my current setup in the case (in my sig).
Any thoughts on this or what to do for a case?
Thanks,
Outlaw
