unfortuanatly, this project does not have anything to do with cows, dogs or fish, which im sure many of you will be extremely disapointed about. That said, its time to move onto the modding its self, no messing about...
The case i will be modding has been completely messed up by my brother and so i will be resurecting it.
this is my work area after a bit of work:
Some work has to be done to the front panel as u can see it has been badly modded previously, so i have removed all the buttons and filled them in with body filler...
then i had to tidy up the hole for the 120mm fan at the bottom.. about 1 inch of sewer pipe was used...
more tomorrow....
