Results 1 to 10 of 12
Thread: To cut or not to cut...
    Fox Furry crenn's Avatar
    In the shadows behind you
    Default To cut or not to cut...
    No, this isn't an emo post
    I've been wanting a PCI-E x1 GPU however I finally got a full quote for a Albatron 9500GT PCI-E x1... at AUD$154, it's a very pricey 9500GT (I can get a normal one for $75-85). I have a perfectly good 8600GT sitting in a box. So I'm consider either removing the back of my PCI-E x1 slot so I can slot in the full 8600GT or modify my 8600GT to fit in the PCI-E x1 slot. What do you guys think?
    Resident EE mtekk's Avatar
    Dec 2007
    Minnesota
    Default Re: To cut or not to cut...
    Cut the back out of the PCI-Ex1 slot, it's the safeist route.
    Quote Originally Posted by xRyokenx View Post
    ...I'm getting tired of not being able to figure this crap out because it's apparently made for computer-illiterate people by computer-illiterate people. lol
    I cut up the 8600GT and it seems I've killed it. At least I didn't kill the motherboard. But I found out something which caused bigger problems, even if I hadn't killed it, I wouldn't be able to fit the GPU into the slot because of the screw and springs at the back... that's the crappiest thing. However, the GPU was only worth AUD$45, and I've learnt that I can't install another GPU unless I get another motherboard.
    If you just need a cheap second gpu to drive a secondary display, why not go PCI?
    I also wanted it to run PhysX on the other card.
    . Spawn-Inc's Avatar
    Feb 2007
    so you can run that card on a single pci x1? if you managed to not kill the card and fit it in the slot?
    Sound: Logtiech Z 5500
    You should be able to. I've heard of it before (although more modifying the PCI-E x1 slot to accept a full 16x card.). I'm going to carefully mod the card to see if I cut a trace or if it's shorting somewhere.
    Feb 2008
    Detroit, Michigan
    Quote Originally Posted by crenn View Post
    Get a PCI 9500GT. I don't think those are too cheap, though.
    Help my mini city
    I'm looking at just holding out until Core i5. Then I'll just keep the current system as a file server (No RAID) or get a new motherboard for it at a later date.
    AARGH dr.walrus's Avatar
    Mar 2008
    Ho Chi Minh City
    Club3D do a PCI-e 4350 pci-e x1, but it's got a double slot cooler. Very cheap though.
    HIS do a PCI-e 4350 too, which is more expensive (about $120 on newegg).
