Anywhere in the UK where you can buy short VGA/SVGA cables, I mean less than 0.5 metre ? thanks they all seem to be 1 metre or more ? thanks or where can you buy the plugs to make your own thanks
buy a meter long one and shorten it? i've never heard of one being that short.
Sound: Logtiech Z 5500
I know that some Video Cards have come with ones about
16" long thereabouts. Anyone out there that has one?
I may have one buried somewhere here, If i can find it
I will let you know. Cost would be whatever shipping is.
EVGA 780I SLI | Vista Home Premium 64-Bit
Intel Q6600 2.4 @3.2 | 1-750 Gig, 1-500 Gig SATA
Corsair 2X 4Gig Matched Sets
Dual 8800GT 512
Thermaltake 850W Modular PS
Hi thanks, im trying to get everything into a wall mounted jukebox and with the cables (svga and serial) been 1.8mts in length it does not help !
Can you post a picture of it? That may help us
help you.
Dual 8800GT 512
I'm pretty sure I have one somewhere - it's about 8 inches long if that helps - it originally came with a monitor/tv tuner where the tuner was a box which mounted on the back of the screen - it's effectively a pass-thru cable - speaking of which - didn't the OLD old voodoo cards have similarly short cables?
http://www.hallresearch.com/mm5/merc...e=UltraThinVGA
These would be what you're looking for. They're pricey but good quality.
They'll do a custom cable if you're willing to pay.
These guys carry their stuff in the UK but I don't see the cables on their website. Worth a call.
http://www.tukans.com/center%20pages/hall.html
How long do you need?
