Since I haven't posted in so long, figured I'd dig through my Photobucket, and find some stuff to post. After falling out of computers, I've still been fiddling with many things!
First, a paintball marker. This is a 2002 WGP Autococker I was given by a local paintballer to trick out. It includes a half-block, and custom pump kit. The half-block use a Jcurt Sled, and a custom brass bolt, with a matching bolt pin, and matching pump arms. The pump kit is a WWA guide rod, with a Harley Davidson 8-Ball that was machined into a pump handle.
Another marker. This is a AGD Automag with a Tac-One body, Cerberus pump kit, and a random handle. The handle needed to be modified to fit, and the owner wanted grooves cut in the rail to match the ones in the body. Pretty straight forward.
My personal Sniper (Bottom Right). In pieces right now. It is based on a O3M, and has a custom 8-Ball pump kit, also has a extended back block I call the "long-Slide." Then the top of the body is milled for dove-tail rails, and has a custom stick-feed. Also has a bunch of internal modifications.
Haha, the back light in a lappy went out. I took some clear LED's, and made a new one. It worked very well. It had a bit more light at the bottom of the screen, but no where near as bad as the picture makes it look.
Heres a guitar effect circuit. A Lm386 based Distortion. My first guitar effect!
My dad was able to pick up a Laserjet printer from where he works. They were going to throw it away. After getting it to work with our network, we figured out why they were throwing it out. The thing jamed every time. After digging around for a few hours, we figured out what it was causing it. One of the gears for the paper feeder was worn, and slipping. We didn't notice it because it really wasn't worn much. The way it was setup though, it was plenty to slip. After noticing a little metal tab keeping the gear from meshing right, we figured might as well try cutting it. Then, it worked perfect! Now I can etch PCB's!
While we had the printer apart, my dad kept dropping the control panel pulling the plug off. Lol, after about the fifth time, the surface mount plug ripped off! So I had to try and solder it back on. All but two of the pads stayed on the board. The other two I ran wires to replace the traces. Soldering right to a surface mount IC leg is not fun! Worked though! Not my best looking solders, but I was more worried about not putting any more stress on the board then how pretty it looks.
That's it for now. I post some more stuff later! When I get my bed room done I'll post some pictures of that! It is the epitome of convenience! I'm a lazy person so I need to set it up so It is is extremely easy to maintain, and to get to my stuff. Necessity is the mother of invention, and all that!
Edit,
Sorry about the long title. Wanted to make sure it was clear, and have a warning about the number of pictures.
Forgive any typos!
Edit 2,
Changed the pictures to links. Some are a little over the file size limit. Didn't want to hurt anyones Internet!
