The NZXT Tempest is the perfect example of maximum cooling fan efficiency in a pc case. Through effective experimentation, research, and product development NZXT has successfully developed a attractive enclosure that is defiantly worthy of the name “AirFlowKing”.
The mid-tower case is slightly larger than average, it features subtle curves and stylish design impressions. The front drive bay covers and areas on top of the case are covered with standard ventilating mesh. A total of (4) 120mm fans, and (2) 140mm fans have been positioned in key locations throughout the case where they are most effective. Warm air rises inside the case, and is then forced out the top by two exhaust fans. Two intake fans are located on the front, and side of the case, they draw cold air into the case cooling the active components inside.
Check out the full review
HERE
