Hi,
This is my first time doing my own window mod and I just have a quick question before I jump right into it.
I am trying to figure out a way to attach the window to the inside of the panel. Ive seen those window kits with the ugly, thick molding... not a fan of that style at all. Here is what I have done so far.
-i measured and marked the back of the panel where im going to make my hole for the window.
-i got a clear acrylic panel with ventilation holes from my local glass shop cut to size (1 inch bigger then the hole on each side).
-I picked up a very thin rubber/plastic molding strip to put around the edge of the hole once its cut and sanded (altho I may end up just diching the molding and repaint that panel)
As i was saying.. im trying to figure out a way to attach the window to the panel. I know I could just drill some holes and bolt it on, but I dont know if I want to do that. I was thinking about using some type of adhesive to avoid drilling holes. Im pretty sure super glue would hold it in place, but im concerned that the heat inside the case may cause the glue to give off fumes which at the least would be an annoyance, and at the worst maybe cause some damage to the hardware.
Is super glue safe to use? Will it give off any fumes when its inside the case or cause any potential damage to the hardware?
Is there a better type of adhesive I should use, or should I just go with the bolts?
thanks so much.
-Dan
