Results 1 to 8 of 8
Thread: Anodizing?
    Default Anodizing?
    Is it electric plating, or powder coating? (I think it's electric.. 'Ano')
    And how hard would it be to set up home anodizing (Assuming I had access to the chemicals)? Do you need special dyes?
    Thanks,
    ~OC
    Jan 2006
    Default Re: Anodizing?
    i know its not electroplating, and i dont think its powder coating, but i believe it is where the aluminum is heated and then a dye is used, but im not sure
    Chicago, IL
    I just did a quick google search and came up with a site about home anodizeing (how lucky is that?).
    Here ya go:
    http://www.artmetal.com/project/TOC/...s/anodize.html
    Thank you for the link!
    I'm not sure if that works on aluminum.. but it should be useful for something. I'm reading another site right now about just that.
    Oct 2005
    massachusetts
    I'm pretty sure aluminum works well with anodizing...
    Quote Originally Posted by wingman358
    Oy.
    I mean, the site that was linked to is general anodizing.. however, there are a bunch of other sites that specifically deal with aluminum anodizing and the chemicals.
    Overclocked
    Jul 2005
    http://www.focuser.com/atm/anodize/anodize99.html This might be waht ur looking for.
    Quote Originally Posted by sXenoG
    Oy, that's the site I'm looking at right now ^_^.
