Results 1 to 4 of 4
Thread: 120mm UV CCFL
    Jun 2008
    MA
    Default 120mm UV CCFL
    looking for a 120mm UV CCFL that mounts into a standard 120mm fan casing. the one I have now seems to have burnt out on me
    Oct 2006
    Spokane, Washington
    Default Re: 120mm UV CCFL
    http://www.xoxide.com/120mm-cold-cat...n-uvblue1.html
    http://www.logisyscomputer.com/produ...AN&DID=COOLDEV
    Most websites only carry the first link, but logisys carries a few UV ones and a few regular ones.
    Hope that helps!
    Edit: Apparently they only make different colored 80mm UV fans except the one 120mm UV fan. Lame. Looks like you're stuck with the one choice then. Of course... you could always just mount it on a different fan of your liking. lol
    Jun 2008
    MA
    thanks for the links, I'm just looking for the outer ring though...not the whole fan
    Oct 2006
    Spokane, Washington
    Try contacting the manufacturer, I'd bet they have the parts. I haven't seen round cold cathodes in a long time. I think Xoxide used to have some, but I couldn't find any.
    You can also try looking into alternative UV methods. You can buy UV LED Molex connectors, UV LED Strips, UV CCFL Fan Grills (costs more than the fan), UV LED RAM Mods, UV LED Spread Light Modules, UV Laser Beams, regular UV LED's, LED Screws, or just regular UV CCFL tubes. Theres lots of options! lol
    (most can be found at Performance-pcs.com)
