Results 1 to 8 of 8
Thread: LCD Replacement Part?
    Oct 2006
    Spokane, Washington
    Default LCD Replacement Part?
    It just struck me that I could probably order a new LCD panel for my currently cracked monitor if I could figure out the company that makes it or where Asus gets theirs from. or maybe I could find one similar enough that would work?
    Anyways, I don't want to crack this thing open and risk further damage so I was wondering if anyone could track down what kind of LCD panel they use in my monitor or find a similar enough one that I could use as a replacement.
    My monitor is an Asus PG221H. Any help would be much appreciated!
    Oct 2008
    MD, USA
    Default Re: LCD Replacement Part?
    Honestly, it would probably be more expensive to get a replacement panel than to get a new monitor. You could even sell off the working parts on ebay. You might even break even
    Oct 2006
    Spokane, Washington
    I'd be willing to spend up to the price of a regular 22" monitor for a replacement screen. This monitor is much more special than 99% of the monitors I've seen out there. I could just buy a new one, but it wouldn't be anywhere near as nice as this one is. I might have to end up doing that anyways though, since these monitors are discontinued. I paid $340 for this monitor by the way. As far as I know, its pretty much one of a kind...
    Oct 2008
    MD, USA
    What about it do you need in a new one? The webcam, speakers or plethora of inputs?
    Oct 2006
    Spokane, Washington
    Bare minimum I need quality speakers and the plethora of inputs. I use this monitor as a television as well as a computer display. As for cost, I wouldn't be willing to go over $200 for a new monitor. I'd be willing to go to $250 for a new display for this particular monitor though. Some other things I like about this monitor are; USB Ports, Subwoofer, Aluminum, Swivel Stand, Webcam and Stunning Aesthetics.
    Oct 2008
    MD, USA
    I don't think any LCDs are made anymore with subwoofers. The one you have is the only one I've ever seen or heard of.
    Aluminum.. I think the only place you might see that under $200 would be an HP like one of these:
    http://www.newegg.com/Product/Produc...82E16824176112
    http://www.newegg.com/Product/Produc...82E16824176110
    What you could do is use the old stand on a new monitor. It might require some modification, but hey, that's why we're here, right?
    As for inputs, in that price range, if you want at least the resolution of the PG221H, the only inputs you're probably gonna be able to find on a new panel are D-SUB, DVI and HDMI (or some subset).
    As for a webcam, ASUS and Apple are really the only manufacturers that I've seen put webcams on monitors.
    This might be close-ish to what you're looking for:
    http://www.newegg.com/Product/Produc...82E16824236048
    Oct 2006
    Spokane, Washington
    And that's exactly why I love my monitor so much. Not much else compares to it.
    I say crack it open and find the make/model on the panel. If you get a new panel, you'll have to open up the monitor anyways.. might as well make sure you 100% have the right one before you order it and spend $$$.
