okay, so, unfortunately no pictures, but here goes.
I have a PC with a radeon 4850 and two ati firemv 2250s. This will soon be three 2250s to give me 8 monitors.
The Case is an old Cooler Master ATCS - it's all aluminium and looks smart, two front fans, one rear, and a massive cooler on the processor (it an AMD Tri-core overclocked from 2.8 to 3.2 ghz)
Occasionally, after extended use, (unsurprisingly) i get graphics driver errors, all six screens flicker a few times, and I get a bluescreen and the PC shuts down.
Should I:
a) build a ducted housing and put a massive fan on the back bigger than the existing 80mm hole
b) put on a massive side fan
c) a + b
d) buy a new case
problem is with the side fan, I have a big power supply (550w, soon gonna be 800), and the power supply has more airflow than the rear fan, so if i push all that hot air up the case, i'll burn out my power supply. Also, with the graphics cards, the Radeon sucks air out the back of the case and the others direct it forward into the case....
Any ideas would be great
