Results 1 to 10 of 20
Thread: 4 x HD4670 vs. 2 x HD4870
    Feb 2008
    Default 4 x HD4670 vs. 2 x HD4870
    I'm currently running two HD4870 cards in Crossfire, but since my board will handle quad-Crossfire I was thinking of running four HD4670 cards instead.
    I like the 4670 because they're smaller and don't require any external power source. (And besides, four cards just looks cooler.) No way am I going to fit four 4870 cards in there and power them and make it look even halfway decent.
    Given that the PCIe will be cut from 16x to 8x with four cards running, does anyone have any opinions on performance comparison between these two setups?
    Jan 2009
    Default Re: 4 x HD4670 vs. 2 x HD4870
    I havne't really seen any difference myself, but if you want to do it, then go for it!
    Whatever can light up, should light up brightly and in many different colors.
    Jun 2009
    Birmingham, AL
    With overclocking you'll beat your setup.
    Just be careful, that's a lot to pull through a board. What board, BTW?
    Oct 2008
    MD, USA
    I would doubt that you would see any performance increase; remember, Crossfire (with 4xxx boards) has better scaling than SLI, but it's still nowhere near 100% (last I saw, with 4xxx boards, it was around 60-65%). So, if you're just going for a performance upgrade, I would say no. Also, Kayin makes a good point; since the 4670 doesn't pull external power, it's pulling all of its power from the PCIe bus..I'm not sure what the upper limit is, but that would definitely be something you would want to make sure you're not overloading.
    Feb 2008
    Quote Originally Posted by Kayin View Post
    An excellent point. I'll be using an Asus M4A79 Deluxe board with a Kingwin 1000-watt PSU.
    Overclocked
    Aug 2006
    why not wait for the ati 5870 instead dx11... comeing out soon.. and the preformance out of 1 card is not bad.. I ran 2 ati 4870 and the preformance I saw with it sucked so I went back to 1 card instead..
    GIVE ME THE CAKE!!! p0Pe's Avatar
    Aug 2007
    proud dane!
    you have to remember, that if you play a game that dosnt support multi gpu´s, then your way down in performance. i would stick with the 2 4870´s. i doubt that you would find anything it dosnt run on max
    is that a 120.9 raddy on your case, or are you just happy to see me?
    METO V.1
    METO V.2
    METO V.3
    PC-Beto
    Project M8 [WIP]
    Jun 2008
    MA
    I'm running a 3870x2 1GB and it plays COD4 on max flawlessly
    Jun 2009
    Birmingham, AL
    I run 2x4870x2s. NOTHING won't run on max on my setup.
    But, as for running Quadfire...
    Dec 2008
    lmao, I would hope so!
    PS3: CaptBuzzCooler
