With cash flow tight right now, the wife and I decided to do home-made gifts for Christmas. I decided to finish Rockin Case for her. While I was workin on that I thought of something else. I saw her Jade bracelet and figured I'd make one out of Acrylic.
sorry for the cell phone pics. if I brought the digi down the wife would have been asking why lol. click on pics for bigger versions
I cut 2 green and one red circle out of plexi
and glued them together
I decided to make it thicker by putting a piece of red on either side. only problem was the red I have is too thick to put on both sides
so I decided to cut it in half
but the bandsaw was too rough, it broke it
so I cut another circle and used a hacksaw to cut it by hand this time
took longer but it worked!
and glued
roughly sanded with her jade bracelet on top for size comparison
and a rough rounded-shape
after 120 grit
after 240 grit
after 1000 grit
after 1500 ad 2000 grit
I cut the inside out with a side cutter bit mounted in the drill press
and a rough rounded sanding of the inside
after 120, 240, 1000, 1500 and 2000 grit
after a polishing with the dremel. started with a buffing wheel with novus polish #3, then #2, then #1.
the weld-on made some interesting "flakes" where the acrylic was glued together. I think it actually made it look pretty neat
and a few shots with better lighting.
I think she'll like it. now to wait for christmas to find out!!
mods feel free to put this in the competed section
