Results 1 to 10 of 15
Thread: XP Pro won't install
    ATX Mental Case The Great Destroyer's Avatar
    Apr 2006
    Fargo, ND
    Default XP Pro won't install
    alright, i got a free pc from work (sans-HDD, they made me destroy all those in my free time). i put my 160gb hitachi drive that i used to have in my desktop in it, along with a spare ati 9200, since it will just be for web surfing. mobo is generic Intel, onboard gpu, 2.4ghz P4, 512 RAM.
    i boot from cd, allocate half the disk for the OS, quick format, and install. after the first reboot the screen goes black and wont load the OS. i reset, and i get an error message on the black screen similar to this, but different .dll file: http://support.microsoft.com/kb/320252
    i try the install again, then i get the hal.dll file seen above error message. so i follow the instructions in the link and completely format the partition before the install. after the reboot, the screen goes all black and i can't do anything except reset. i take the disk out and try it again, and i still get the hal.dll error message.
    If it ain't broke, fix it 'til it is!
    Jun 2008
    MA
    Default Re: XP Pro won't install
    bad install disk maybe?
    Aug 2005
    Sunderland, Tyne & Wear, UK
    That would be my first thought too - I've seen multiple installs fail because I kept forgetting to throw out a disk, and it was always something along those lines.
    Aug 2009
    Michigan
    Is the HDD IDE or SATA? If it's IDE, then I don't have a whole lot to say. But if it's SATA, then try starting the installation process with the startup floppy disks. Since XP was coded before SATA was standardized it can do some pretty funky things with SATA HDDs when random, non-standard SATA drivers are present. A slip-streamed install disk with at least the first SP should install fine though too. It's also a more useful alternative than floppies...but so is anything else.
    I'll procrastinate tomorrow.
    Apr 2006
    Fargo, ND
    its IDE. and it may be the install disk. previous disk i was using used to BSOD after loading drivers. i'll try that and see if a new disk works *hunts hard drive for the .ISO file*
    Apr 2006
    Fargo, ND
    well, i just burned a new cd, and its stuck on the black screen again after the first reboot, so im starting to think its a hdd problem.
    Mar 2007
    Aiken, Sc
    Try installing Ubuntu onto the drive to rule out a bad HDD.
    Custom Title Honors Snowman's Avatar
    Jul 2008
    B F E
    I had this same issue had to stick an nvidia card in to install windows and then swap out for my ati card
    Regedit'ed, Rooted, and Jailbroke anymore questions?
    Here’s a bumper sticker I’d like to see: “We are the proud parents of a child who’s self-esteem is sufficient that he doesn’t need us promoting his minor scholastic achievements on the back of our car.”
    Check the ram.. always my second guess when doing an install (after bad source disc).
    Apr 2006
    Fargo, ND
    good idea. guess i'll run memtest86 after i get out of class today.
