Bopher
First of welcome to the forums, as you can see there are a ton of people here who are willing to help with almost anything. I think I can at least answer you question on using the reset button for the CD drive. You can rewire the button to work and I know I have a wiring diagram somewhere for it, but keeping that control board inside you lose about a 1" by 2" area in space which as you know is very tight inside the NES shell. Remove the bottom plate from the drive and find the solder points up by the button and hook right into those. With my build I have the power for power and the reset for the disk drive. The power button is a tad trickier but is fairly quick to work out.
