Results 1 to 4 of 4
Thread: How to etch plexiglass
    ERAU
    Default How to etch plexiglass
    How do you recomend to etch a design into plexiglass?
    I have seen Glass Etching Cream but do they make it for plexiglass?
    Overclocked Guttenaffe's Avatar
    Ohio
    Default
    Yes, they also make spray cans that are around 90psi and have etch particles in it, does something like a sandblast etch. Go to a craft store and ask the people there they will probably know tons of other ways to do this.
    A good plastic film stencil and coarse sandpaper works well, and there are always the dermel etch bits.
    I'd get a small piece of plexy and try what ways you like and see which works the best for you. What works for one person donít always works well for others, esp. the dremel bits, some might think they are the best thing ever other might think they are impossible to control.
    -Gutte
    No, I'm not a compleate Idiot!
    Some parts are missing.
    Overclocked
    Default
    Well you just won that dremel so sound slike a project for it when you get it. Most likely that kit has engraving bits.
    here is a couple guides.
    http://guides.pimprig.com/modding/ka..._technique.php
    http://www.bjorn3d.com/read_pf.php?cID=319
    there is other guides and lots of threads out there.
    Mesh makes the world go around!!!!
    Overclocked
    Toronto
    Default
    Quote Originally Posted by R/C Pilot
    It's an acid, and will etch acrylic.
    When computers collide, Bob is born
    And remember, boys and girls, it's better to say nothing, if that's what you know.
  1. Frosted plexiglass.
    By dlpriest in forum Idea Zone
    Last Post: 09-25-2006, 03:52 PM
  2. Plexiglass
    By Vanquish in forum The Rookie's Nook
    Last Post: 03-05-2006, 10:34 PM
  3. uv plexiglass
    By DeathCrush in forum Modding Q&A
    Last Post: 12-03-2005, 01:31 AM
  4. plexiglass shapes
    Last Post: 11-24-2005, 01:16 PM
  5. Cutting Plexiglass, a few questions
    By NeroZero in forum The Rookie's Nook
    Last Post: 07-19-2005, 05:35 PM
