no video but the fan spins up and theres no sounds on the on board speaker any ideas whats wrong
Power connector to the card is plugged in?
No video from either video output?
Is the monitor and cable confirmed as working?
Does the card work in another machine?
Does another card work in that machine?
Is the heatsink seated properly?
Does the card work if it's cooled sufficiently before retrying?
Also, I would reseat the ram on the motherboard, and try to reseat the card as well.
Waterblock? That makes me worry right there. Over tightening the waterblock mounting hardware can cause damage, not seating it properly can cause heat issues leading to failure, water damage could kill it as well.
If you do have warranty on it, return it to stock before trying to get it RMA'd.
What about that 7900gt I dropped in the box for you guys?
Were you playing GTA IV by chance when the card quit?
GTA IV killed my original 8800GT and causes my 8800GTS to overheat unless I use riva tuner to turn the fan above 80%
Charles (CJ) Gantt: Coil Gun // Biohazard // Circuits // 3D Printer // CoD MW2 Case // TBCS 4GHz Club
Sites: The Makers WorkBench // CJ Gantt Photography
