crazybillybob
McMaster Carr
Punch it into Google and you'll get an online catalog. They sell all kinds of Plastics. Do a Catalog search for Plexiglass and you'll get what your looking for.
Don't use that car tint, It doesn't stick well to plex (the static build up on the plastics surface), you'll get those cheapy looking purple bubles all over your case, you know the kind that show up in cars when it's not right.
Get the colored Plex (yes the color is in the plex, it's part of the plastic, so you cut it and the edge is the same color clear through...)
Take a look in the work logs @ Circuse de Soile (I spelled it wrong). He's making his whole case from yellow colored Plex...Looks great, and it will give you more Ideas...or Look at any thing from Defyant...He is a master with Plex, and his work logs go through things step by step, so you can learn too.
Good Luck,
CrazyBillybob
(I'm a wood, styrene, and Aluminum builder myself)
