Results 1 to 6 of 6
Thread: Hard drive formatting software?
    Feb 2008
    Default Hard drive formatting software?
    I've run up against an odd problem: I have a hard drive that I want to format so I can use it for other things, but it won't let me. Using Win7, all it tells me is "Windows was unable to complete the format". I can't even delete the files individually manually.
    Can anyone recommend a simple freeware (or shareware) third-party program to do this?
    Aug 2009
    Michigan
    Default Re: Hard drive formatting software?
    I haven't had to use it in years, but KillDisk will format it outside of Windows. You'll have to use their utility to make a bootable floppy or CD and boot from that. Actually, I haven't used it since floppies were still legit. It's been a while.
    I'll procrastinate tomorrow.
    Aug 2005
    Sunderland, Tyne & Wear, UK
    I wrote an article a couple months ago on installing windows 7 on a netbook via usb - you might want to take a look at that, specifically page 2 (http://www.thebestcasescenario.com/f...441&page=0%2C1) which shows you how to use a command line interface to prepare and format a drive. I only mention it because I had an issue with a USB stick a while back - I made it into a bootable eeepc linux recovery device, and it went from 2gb to 1.3 and nothing I could do with the graphical tools in windows would get that other 700mb back once I was done, but this command line tool did it no problem. I'm assuming from that experience that this tool works on a lower level than the graphical ones in windows itself....
    You'll have to ignore the bit about using a win 7 DVD and the bit at the end about copying the files, but I think all of the command line bits might well help.... With a little minor modification of course
    Administrator OvRiDe's Avatar
    Dec 2005
    Tulsa, OK
    DBAN is a great utility for wiping the disk. It comes as a bootable CD so that Windows doesn't have control of the drive. Once its wiped, Windows should have no problems formating it.
    http://www.dban.org/
    Oct 2008
    MD, USA
    ++ for DBAN
    --Benjamin Franklin
    Feb 2008
    Excellent, thanks very much all!
