ok guys, so as you've probably seen in my worklog, I'm about to create the world's first watercooled sandcrawler. But...a question first.
Does it completely defeat the purpose of 24-hour leak testing to drain the setup after the test so I can detach the waterblocks to make them easier to install on the motherboard/video card? Or is leak testing primarily to make sure the fittings all..well...fit, and don't leak?
I'm just thinking that it'll be awkward to try and put everything together if it's all connected by various hoses which restrict relative motion.
I consider myself a newbie at this; I once had another watercooling setup, but that was around 6 or 7 years ago, and I don't recall much from it.
Thanks!
