Hi all!
Couldn't realy decide where this should go, so if it is in the wrong place could a mod please move it! Thanks! sorry to be a pain!
Now then. I was in PCworld earlier with my mum looking at laptops (I get 10% off all toshiba laptops with my UCAS card so we were trying them out) and she actualy suggested replacing my two old 15" CRT monitors with a nice flat screen. and I quote, "Maybe if you got rid of those ugly things your room would look a little less like a slum."
I have a budget of 200 quid, though if it will REALY benefit me I can stretch to around 225-230. I cannot go any higher than that though. I need to find a nice flat screen monitor with a fast response time as I plan to use it for gaming. I want to be able to make the most of my 7900gtx and I dont think that I will be able to with a crappy monitor. I know NOTHING about monitors however! If somebody could reccomend one or help me get a better idea of what I need to look for/some good brands/types etc.
Does it realy make a big difference whether they are DVI or VGA? the card im getting has 2 DVI outputs so if it was vga I would have to use an adapter, would this be a problem?
Thanks again for your help!
H
